NEAS_WriteValue
Require: IP-Symcon >= 4.0
 boolean NEAS_WriteValue (int $InstanceID, string $Ident, variant $Value)
ID of the Instance
Ident
Ident of the variable
Value
Value of the variable
Writes the Value Value to the variable with the ident Ident in the NEA Smart with the InstanceID InstanceID.
NEAS_WriteValue(12345 , "HEATAREA1_T_TARGET", 23.3);
