Möhlenhoff Alpha 2
Require: Symcon >= 4.0
The module is used for receiving and switching Möhlenhoff Alpha2 data.
Function scope
  • Setting variables via script command or Visualization.
  • Reading out the data of the Möhlenhoff Alpha 2
Software installation
  • Install the Möhlenhoff Alpha 2 module via the Module Store.
Instance setup in IP-Symcon
  • Under "Add Instance" the 'Möhlenhoff Alpha 2' module can be found using the quick filter.
Configuration page:
Name Description
IP address IP address of the Alpha 2
Interval Adjustable interval in seconds in which the data of the Alpha 2 should be queried. (Default: 0)
Heating zone 1..12 Activates the readout of the respective heating zone. (The heating circuits are always all read out)
"Read out device" Reads out the data manually. Must also be done once at the beginning.
status variables and profiles
Statusvariables
The variables are created automatically.
Name (base) Type Description
Base Setback Temperature Float Serves as a "category" in which all monitored locations, as well as the time stamp and longitude/latitude are located. Created per device.
Base Setback Input Boolean
Basic Automatic Time Change Boolean On/Off of automatic time change
Basic Operating Mode Heating/Cooling (CO input) Boolean Controls the operating mode (On = cooling, Off = heating)
Basic Frost Protection Boolean On/Off of Frost Protection
Basic Frost Protection Temperature Integer Temperature of Frost Protection
Base HW Version String Hardware Version of the Base
Base ID String Base ID
Base Cooling Mode Boolean Cooling Mode On/Off
Base Rank in System Network Integer Edge of Base (0 = Standalone, 1 = Master, 2 = Slave)
Base Smartstart on/off Boolean On/off of Smartstart
Base SW ETH Version String Software Version Ethernet
Basic SW STM Version String Software Version STM
Basic Dewpoint Sensor Boolean On/Off of Dewpoint Sensor
Basic Temperature Limiter Boolean On/Off of Temperature Limiter
Basic Temperature Unit Integer Setting whether Fahrenheit or Celsius (0 = °C, 1 = °F)
Basic Vacation Status Integer Vacation Status (0 = off, 1 = scheduled, 2 = active)
Base Vacation Temperature Heating Float Temperature during vacation
Name (heating zone 1..12) Type Description
Heating Zone 01..12 Actual Temperature Float Actual Temperature
Heating zone 01..12 set temperature float set temperature
Heating zone 01..12 Operating mode Integer Operating mode of heating zone (0 = Auto, 1 = Day, 2 = Night)
Heating Zone 01..12 Actual Temperature Ext. Sensor Float Current Actual Temperature of External Sensor
Heating zone 01..12 Presence Boolean On/Off of presence
Heating zone 01..12 Heating system Integer The heating system used (0 = FBH standard, 1 = FHB low energy, 2 = radiator, 3 = convector passive, 4 = convector active)
Heating zone 01..12 Correction of actual value recording Float Correction of actual value (-2.0 .. +2.0)
Heating zone 01..12 Name String Name of heating zone
Heating zone 01..12 Party switching (hours) Integer How many hours the party switching should run
Heating zone 01..12 Party time remaining (min) Integer How long the party mode is still active
Heating zone 01..12 Weekend program Integer Which time program is active at the weekend
Heating zone 01..12 Program weekdays Integer Which time program is active during the week
Heating zone 01..12 Setpoint temperature max Float Setting range setpoint temperature (maximum)
Heating zone 01..12 Set temperature Min Float Adjustment range set temperature (minimum)
Heating zone 01..12 Status Boolean Status display (0 = OK, 1 = Error)
Heating circuit 1..12 Active Boolean Whether the heating circuit is active (0 = No, 1 = Yes)
Heating circuit 1..12 Actuator Boolean On/Off of actuator
Heating circuit 1..12 actuator percent Integer Percentage activity of the actuator (Only with SW STM version 2.02 or higher)
Heating Circuit 1..12 Status Integer Status (0 = Off, 1 = On, 2 = Error)
Heating circuit 1..12 assigned heating zone Integer Which heating zone is connected to the heating circuit
Profile:
Name Type
MH.AntifreezeTemp Integer
MH.TemperatureUnit Integer
MH.SummerWinter Boolean
MH.ChangeOver Boolean
MH.Mode Integer
MH.EcoDiff Float
MH.VacationState Integer
MH.PumpTime Integer
MH.RelayTime Integer
MH.EmergencyTime Integer
MH.PWMCycle Integer
MH.PWMPercent Integer
MH.HeatAreaMode Integer
MH.HeatAreaProgram Integer
MH.HeatAreaParty Integer
MH.HeatAreaPartyRemainingTime Integer
MH.HeatAreaState Boolean
MH.HeatAreaRPMMotor Integer
MH.HeatingSystem Integer
MH.HeatAreaTActualTemp Float
MH.HeatAreaTTarget Float
MH.HeatAreaTHeatCool Float
MH.HeatAreaOffset Float
MH.HeatAreaBlockHC Integer
MH.HeatAreaHeatCTRLState Integer
MH.HeatAreaNo Integer
MH.HeatCtrlActorPercent Integer
Visualization
Via the Visualization or in the mobile apps, values are displayed and can be changed if possible.
Due to the amount of variables we recommend to disable the display of the whole Alpha 2 in the admin console and display all desired variables via links in a separate category.
