MA2_RequestStatus
Require: IP-Symcon >= 4.0
 boolean MA2_RequestStatus (int $InstanceID)
ID of the Instance
Gets the values stored in the Alpha2 with the InstanceID InstanceID and sets the associated variables.
MA2_RequestStatus(12345);
