Device list
Supported Gateways/Components
IP-Symcon supports all devices that use the ModBus RTU or ModBus TCP protocol.
In particular, devices and PLCs from Wago/Beckhoff/ABB.
Supported Components
IP-Symcon supports all components.
Manufacturer Description
SymBox with RS485 (ModBus RTU) extension Order now Serial integrated module
Exsys EX-6051 (nonbinding recommendation) Serial to LAN converter for mode "ModBus RTU over TCP"
Waveshare RS485 to Ethernet Converter (nonbinding recommendation) Serial to LAN converter for mode "ModBus RTU over TCP"
