Meter Overflow
Require: IP-Symcon >= 4.2
The module represents overflowing counters as continuous counters.
function scope
  • Calculates the total value of a variable and counts it up even though the device has an overflow.
Software installation
Set up instances in IP-Symcon
  • Under "Add Instance", the 'Meter Overflow' module can be found using the quick filter.
Configuration Page:
name description
Source Source variable to be used for the calculation.
Maximum value From which value an overflow takes place. The maximum value which the device will count.
status variables
Status variables
name type description
Counter Float Continuously incrementing value.
