FD-868
Function
The radio display 868 is used to display text messages on a 2 x 16-character LC display.
In addition, three LEDs and a buzzer can be switched.
Optional is an IO box (relay board) with two outputs (10A/250V) and two inputs (TTL +5V) available.
The bidirectional data transmission takes place via an USB radio transceiver operating in the 868 MHz frequency band.
Installation
Configuration
The following properties can be changed as follows (not by command): hold left button on the display and switch the device on. Follow the further instructions on the screen.
| Value | Description |
| Device-Address | By default, the ID: 1 is set. If more displays are available in a system, a new ID will be awarded. |
| Group-Address | Here all displays e.g. of the ground floor will be addressed together. This feature is not available in the first generation. |
| Broadcast-Address | Fixed: 255 - all displays will be addressed together |
| Key click | On/ Off |
Only one device with the same ID may be present in a radio network.
Optional is an IO box (relay board) with two outputs (10A/250V) and two inputs (TTL +5V) available. RJ-11 socket assignment (Display):
1 – Input 1 / TTL
2 – GND
3 – Output 1 / Open Collector
4 – Output 2 / Open Collector
5 – VCC /+5V
6 – Input 2 / TTL
IO-BOX socket on the terminal of ‘Output 1′
Tips & Tricks
Scripts for a menu control are available in our forums:
Link to the forum post
You can not turn off the key-click in the first generation.
It signaled to the operator that the command from the USB radio transceiver has been adopted (Acknowledgment).
