PJ_SetVoltage
boolean PJ_SetVoltage (int $InstanceID, float $Volt)
InstanceID | Device ID |
Volt | Voltage to which the output is to be set |
Sets the output to Volts for the device with ID InstanceID. Values higher than 10V are limited automatically.
//Sets the output voltage to 5.30 volts
PJ_SetVoltage(12345, 5.30);
