ANA-868
The analogue-digital/ digital-analogue converter module has 2 analogue inputs (10V, input impedance 10kOhm) and 2 analogue outputs (10V/10mA).
Installation
In order to read in the data from measured voltages or to be able to set voltages at the outputs, an 868 Gateway must first be connected and set up. An "ANA-868 (analog input/ analog output)" module must be added in IP-Symcon. The parent instances (e.g. the gateway) are created/connected automatically.
Configuration
Value Description
Device Address The ID:184 is specified by default. If there are more controllers in a system, a new ID must be assigned. The jumper assignment can be found in the operating instructions.
Channel Address (1-4) Indicates which of the two output/input channels should be used.
