BA_AddImage
Require: IP-Symcon >= 4.2
boolean BA_AddImage (int $InstanceID)
Copies the current source image to the "Images" category of the 'Image Archive' module with InstanceID InstanceID. The function does not return any value.
BA_AddImage(12345);
