Image Archive
Require: IP-Symcon >= 4.2
The module copies an image when triggered by a selected variable. It is adjustable how many images should be saved.
Function scope
- Selectable source image and selectable trigger variable
- Adjustable number of images to be saved
- When a trigger variable is selected, an event is created that reacts to its update
- The event can be fully personalized except for the trigger variable
- Images get the time of triggering as name
- Images are displayed chronologically from old -> new in the category images
- Automatic deletion of the oldest images, when the maximum number of images is reached
software installation
- Install the 'Image-Archive' module via the Module Store.
- Under "Add Instance" the 'Image-Archive' module can be found using the quick filter.
configuration page
Name | Description |
Image | Source image to be copied |
Number | Maximum number of images to be saved |
Trigger Variable | Variable at whose change the source image should be copied to the archive |
status variables
Statusvariables
Name | Type | Description |
Images | Category | The source images are copied into here |
AddImage | Event | Triggered by the trigger variable and triggers the copying of the source image |
Visualization
The Visualization is used to display the variable. No further control or separate display is integrated.
To display the images in the 'Bildarchiv' category, a content divider can be added in the Visualization or a link of the category can be made.
Attention: It is not useful to link directly the images from the archive, because the updates change the ID's.
