Group Control
Require: IP-Symcon >= 5.0
With the help of the 'Group Control', variables can be switched together in groups.
function scope
- When one variable in the group is switched, all remaining variables in the group are switched as well
- All variables that are added to a list can be switched with a separate variable at the same time
Software installation
- Via the Module Store install the 'Group Control' module.
Under 'Add Instance' the 'Group Control' module can be found using the quick filter. - More information about adding instances in the Instances documentation
Configuration Page:
Name | Description |
Variables | The variables present in this list belong to the group; All variables must be of the same type and have the same profile and an action |
status variables
Status variables
Name | Type | Description |
Status | variant | Displays the status of the current group |
Visualization
This displays the status variable that can switch the group.
