Light (Switch)
Require: IP-Symcon >= 5.0
Devices of the type Light (Switch) describe lamps that can be switched on or off.
Parameter
Name Description
Name Name that is used to address the device via Google Assistant
Variable A triggerable variable of type Boolean, that switches the light on or off
Possible Actions
Switch On or Off Triggers the variable to True or False "Ok Google, switch <Name> on."
Variable Possible Profiles
Switch Variable ~Switch
