Expert Options
Require: IP-Symcon >= 5.0
The Expert Options usually do not need to be adjusted. Handle these options carefully to ensure that the Google Assistant module works as intended.
Options
Name | Description |
Emulate Status | If Emulate Status is active, the module does not wait for the update of switched variables. Instead, it returns the new state based on the triggered value. |
Request device update | A device update can be requested from Google with this button, synchronizing the configured devices again with Google Assistant. This is usually done automatically when applying changes. |
