smart SILENO Mower
Require: IP-Symcon >= 6.0
The smart SILENO Mower offers various services in IP-Symcon, which make it possible, for example, to recognize the current activity of the device or to start or stop the mowing process.
Services
For each service, an instance can be created with the configurator.
Service | Description |
General | Contains general information about the device |
Mower | Represents the SILENO mower |
General
The following status variables are created for this instance
Variable | Type | Description |
Battery status | String | The status of the device's battery |
RF Link Level | Integer | The quality of the wireless connection in percent |
RF Link Status | String | The status of the wireless connection of the device |
Mower
Activity | String | The current activity of the device |
Operating hours | Integer | The time the mower has been active for, in hours |
Error code | String | The last error transmitted |
Status | String | The current state of the device |
Cutting duration | Integer | The time in minutes for manual mowing |
Mowing | String | Allows the mower to mow for a specific mowing time or according to a schedule |
Parking | String | Allows the mower to drive to the charging station |
The following actions are available for this instance
Action | Parameters | Description |
Automatic mowing | (none) | Makes the mower mow on schedule |
Manual mowing | Duration (minutes) | Makes the mower mow for the specified time |
Park until the next task | (none) | Makes the mower drive to the charging station and wait for the next task |
Parking and ignore the schedule | (none) | Makes the mower drive to the charging station and ignore the schedule |
