Number Guessing
Require: IP-Symcon >= 5.0
range of functions
  • A little game where a random number has to be guessed.
Software installation
  • Under "Add Instance" the 'Number Guessing' module can be easily found using the quick search.
Configuration page:
name type description
Minimum of the generated number Integer The minimum of the number that will be generated.
Maximum of the generated number Integer Maximum of the generated number.
Number of allowed attempts Integer The number of attempts the player has to guess the number.
status variables
Status variables
Name Type Description
Moves left Integer Shows the number of remaining attempts.
Your number is String Shows if the guess is greater or less than the number to guess.
Your Hint Integer The input field for the player's hint.
Visualization
This is where the game is played.
