Fault Manager
Require: IP-Symcon >= 6.0
The module is used to display active variables in the Visualization and, depending on the setting, to hide them after they have been entered or deactivated. If 'Auto hide' but not 'Confirmation' has been activated, a link will be visible as soon as the monitored variable is active. This link disappears as soon as the monitored variable is deactivated. If 'Confirmation' and 'Auto Hide' have been activated, a variable will be created as soon as the monitored variable is active. This disappears as soon as the value of the created variable has been changed to 1 or 'In process' and the monitored variable is inactive. If 'Confirmation' but not 'Auto Hide' has been activated, a variable will be created as soon as the monitored variable is active. This disappears as soon as the value of the created variable has been changed to over 2 or 'All right'.
function scope
  • Display of active variables
  • Possibility to acknowledge them depending on the selection
Software installation
  • Under "Add Instance", the 'Fault Manager' module can be found using the quick filter.
Configuration Page:
Name Description
Variable Variable to be monitored.
Confirmation Checkbox to confirm or not the message.
Hide automatically Checkbox, so that the message is automatically hidden again when the state is deactivated.
Message handling Selection how to handle the variables when they are active.
status variables and profiles
Status variables
Name Type Description
Link: Variable Name Link Link which is visible or invisible. Will be created if 'Message disappears automatically' is selected.
Variable Names - Status Integer Variable which is created when 'Acknowledge message' or 'Acknowledge message, disappears when error is cleared' is selected.
Profile:
name description
STA.Confirm Profile for created variables, with 3 levels
STA.ConfirmHide Profile for created variables, with 2 levels
Visualization
Via the Visualization the created variables are displayed and can be changed if they need to be confirmed.
