ENO_SwitchMode
boolean ENO_SwitchMode (int $InstanceID, boolean $Status)
Status | TRUE for On, FALSE for Off |
Switches the device with ID InstanceID to value Status
Since the EnOcean system is unidirectional, can not be determined whether the command was successful. Error messages are only sent when an internal system error occurred (for example, if the interface is not connected).
ENO_SwitchMode(12345, true); //Turn on device
