EZI_Update
Require: IP-Symcon >= 4.2
 boolean EZI_Update (int $InstanceID)
ID of the Instance
Updates the calculated values of the 'Energy Counter Pulse'-module with the InstanceID InstanceID.
EZI_Update(12345);
