Energy Counter Power
Require: IP-Symcon >= 4.2
The module calculates the instantaneous and cumulative power consumption via an electricity meter (current or power).
function scope
- Calculates instantaneous power consumption in watts and total power consumption in kWh.
- Adjustability of type and source of the counting device.
- Adjustability of the interval frequency in seconds to recalculate the consumption if the source variable has not changed.
Software installation
- Install the 'Energy Counter Power' module via the Module Store.
- Under "Add Instance", the 'Energy Counter Power' module can be found using the quick filter.
Configuration Page:
Name | Description |
Type | Is the source variable of type power (W) or current (A). |
Source | Source variable to be used for the calculation. |
Voltage | Voltage (V) to be used for conversion. |
Interval | At which seconds interval the calculation should be automatically recalculated if the source variable has not changed. |
status variables
Status variables
