Done Notifier
Require: IP-Symcon >= 4.2
The ready indicator signals whether a device is ready. For this purpose, the variable of the power consumption of the device is selected and a limit value is defined. As soon as this limit value is exceeded for the first time, the ready detector is started. If the power consumption falls below this limit value and does not exceed it again within an adjustable period of time, the status variable is set to "Ready".
function scope
  • Switching the entire module on/off
  • Selection of a source variable
  • Setting the limit value
  • Time span until ready message is set after limit value is undershot
software installation
  • Under "Add Instance" is 'Done Notifier' module can be found using the quick filter.
Configuration Page:
Name Description
Source Source variable which is used for comparison with the limit value.
Limit Value below which a ready message is set.
Interval Period until a ready message is set. Only becomes active after the value falls below the limit value.
status variables and profiles
Status variables
Name Type Description
Active boolean Turns the module on/off
Status integer Indicates the status (Off/Running/Complete)
Profile:
Name Type
FM.Status Integer
