CSV_Export
Require: IP-Symcon >= 5.5
string CSV_Export (int $InstanceID, int $ArchiveVariable, int $AggregationStage, int $AggregationStart, int $AggregationEnd)
ArchiveVariable | VariableID, which should be exported |
AggregationStage | Aggregation level analogous to AC_GetAggregatedValues |
AggregationStart | Date/time as Unix timestamp (0 = from beginning) |
AggregationEnd | Datum/Zeit as Unix timestamp (0 = until now) |
The relative path of the zip archive.
Creates a zip archive based on the given parameters and returns the relative path of the archive.
CSV_Export(12345, 54321, 4, 2293574400, 3127161600);
