CSV ZIP Export
Require: IP-Symcon >= 5.5
This module provides the possibility to export the aggregated values of a variable as a CSV file in a ZIP archive.
function scope
- Exporting aggregated data of a variable
- Export data to CSV file in a ZIP archive
- Listing of all logged variables
- Period of aggregation can be freely selected
- Aggregation level can be selected
- Cyclic creation and sending of an archive
software installation
- Install the 'CSVZipExport' module via the Module Store.
- Under "Add Instance", the 'CSV-ZIP-Export' module can be found using the quick filter.
configuration page
Name | Description |
Filter | Filters the selection of logged variables |
Logged Variables | Selection of the variable to be exported |
Start of aggregation | Start of aggregation period |
End of aggregation | End of aggregation period |
Decimal separator | Selection of decimal separator comma or point. |
Aggregation Level | Level of Aggregation |
Export | The aggregated data of the variable will be exported |
Enable cyclic send | Enable send by email |
SMPT Instance | Select Email Instance |
E-mail Interval | Interval in which the e-mail is sent. With "Weekly" the e-mail will be sent on Monday and with "Monthly" the e-mail will be sent on the 1st of each month at the selected time |
Time of the mail | Time at which the e-mail is to be sent |
Send mail now | Sends a mail manually |
