Consumption per Category
Require: IP-Symcon >= 6.3
Calculates consumption in percent per freely selectable category according to specified start and end dates. The calculation is based on daily aggregation.
function scope
  • Selection of multiple variables
  • Free text for category
software installation
  • Install the 'Consumption per category' module via the Module Store.
Instance setup in IP-Symcon
Under 'Add instance' the 'Consumption per category' module can be found using the quick filter.
Configuration page:
Name Description
Interval Interval in which the calculation is executed. 0 = Disabled
Sources List of variables and categories
status variables
Status variables
Name Type Description
Category Float A variable is created per category, in which the percentage consumption is displayed. The category name is internally reduced to A-Z, a-z, 0-9 and _ (underscore). This means that the category "Test" and "Test €" will also be categorized to "Test".
Start time Integer Date from when the calculation should start
End time Integer Date until when the calculation should go
