Computation Module
Modules, which enables various calculations within IP-Symcon
Computation ModuleCalculation of different auxiliary values based on a group of variables, e.g. buzzer or average.
RM_UpdateUpdates the calculated values
ConverterConverts a variable using a self-defined formula.
UMR_CalculateCalculates the return of the formula for the Value and returns it.
ConvertMultiBoundariesConverts a variable within set limits using a self-defined formula.
UMG_CalculateCalculates the return of the formula for the value __Value__ and returns it.
ValueRangeScaleSkalierung eines Wertes innerhalb eines Wertebereiches
VRC_ScaleScales the input variable value
