VM_Update
Require: IP-Symcon >= 5.5
 boolean VM_Update (int $InstanceID, float $PrimaryDelta)
ID of the Instance
PrimaryDelta
Positive Veränderung der Hauptmessstelle
The slope of the secondary measuring points is added or subtracted depending on the selected option. The result is added together with the passed value to the value of the 'Result' variable.
VM_Update(12345, 5.3);
