AC_ReAggregateVariable
Require: IP-Symcon >= 3.0
 boolean AC_ReAggregateVariable (int $InstanceID, int $VariableID)
ID for the archive
VariableID
ID of the variable to be re-aggregated
This function starts the re-aggregation of the variable with the ID VariableID.
Re-aggregation can take a long time. The current progress of the re-aggregation can be checked via regular entries in the message window.
// This starts the re-aggregation of the variable "test variable"
AC_ReAggregateVariable(39147 /*[Archive]*/, 53716 /*[TestVariable]*/);
/* Sample output in the message window
07.10.2015 15:50:05 | Archive Control | Reaggregation for VariableID #53716 is in progress... 10/2015! (6 rows)
07.10.2015 15:50:05 | Archive Control | Reaggregation for VariableID #53716 is complete! (6 rows)
