AC_GetAggregationVariables
Require: IP-Symcon >= 3.0
array AC_GetAggregationVariables (int $InstanceID, boolean $DatabaseQuery)
InstanceID | ID for the archive |
DatabaseQuery | True, if additional information is to be displayed, otherwise False (with version 4.0 and above unimportant, but required) |
An array with the following key => value pairs.
Index | Type | Description |
FirstTime | integer | Date/time from the beginning of the aggregation period as a Unix Timestamp |
LastTime | integer | Date/time of the last entry of the aggregation period as a Unix Timestamp |
RecordCount | integer | Number of records |
RecordSize | integer | Size of all data records in bytes |
VariableID | integer | ID of the variable |
AggregationType | integer | Aggregation type as an Integer. See also AC_GetAggregationType |
AggregationVisible | boolean | Indicates whether the variable is displayed in the visualization. See also AC_GetGraphStatus |
AggregationActive | boolean | Indicates whether logging is active for this variable. See also AC_GetLoggingStatus |
With version 4.0 and above the specified parameter DatabaseQuery is no longer used. However, this must be specified for downward compatibility.
This function returns an array of all logged tags of the archive handler with the ID InstanceID. Additional information about each variable can be activated with DatabaseQuery. (Functional up to version 3.4)
// Output with additional information
var_dump(AC_GetAggregationVariables(39147 /*[Archive]*/, true));
// Sample output:
array(1) {
[0]=>
array(8) {
["FirstTime"]=>
int(1444221643)
["LastTime"]=>
int(1444221705)
["RecordCount"]=>
int(6)
["RecordSize"]=>
int(78)
["VariableID"]=>
int(53716)
["AggregationType"]=>
int(0)
["AggregationVisible"]=>
bool(true)
["AggregationActive"]=>
bool(true)
