Temperature Sensor
Require: IP-Symcon >= 5.0
Devices of the type Temperature Sensor measure temperatures.
Parameter
Name | Description |
SensorVariable | A variable of type Float that contains the current temperature in °C |
Possible Actions
Currently, Alexa does not support direct requests to a temperature sensor. Thus, a group needs to be used to request the temperature via voice command. Once the temperature sensor is part of a group, the temperature of that group can be requested.
Request temperature | Request the current temperature of the sensor | "Alexa, what's the temperature of |
Device Search
