Light (Dimmer)
Require: IP-Symcon >= 5.0
Devices of the type Light (Dimmer) describe lamps that can be dimmed.
Parameter
Name | Description |
Variable | A triggerable variable of type Integer or Float that dims the light |
Possible Actions
Switch On or Off | Trigger the variable to 100% or 0% | "Alexa, switch <Name> on." |
Dim | Trigger the variable to the given value | "Alexa, dim <Name> to 40%." |
Device Search
Variable | Possible Profiles |
Variable | ~Intensity.100, ~Intensity.255, ~Intensity.1 |
