Light (Color)
Require: IP-Symcon >= 5.0
Devices of the type Light (Color) describe lamps, that can be switched to any color.
Parameter
Name | Description |
Variable | A triggerable Variable of type Integer with the profile ~HexColor, that triggers the color of the light |
Possible Actions
Switch On or Off | Trigger the variable to white or black | "Alexa, switch <Name> on." |
Dim | Trigger the brightness of the current color to the given value | "Alexa, dim <Name> to 40%." |
Switch Color | Trigger the variable to the given color | "Alexa, switch <Name> to red." |
Device Search
Variable | Possible Profiles |
Variable | ~HexColor |
