Generic Switch
Require: IP-Symcon >= 5.0
Devices of the type Generic Switch can be switched On or Off. Within Amazon Alexa, the device is interpreted as a common switch and can be used for different devices.
Parameter
Name | Description |
Switch Variable | A triggerable variable of type Boolean |
Possible Actions
Switch On or Off | Trigger the variable to True or False | "Alexa, switch <Name> on." |
Device Search
Variable | Possible Profiles |
Switch Variable | ~Switch |
