Generic Slider
Require: IP-Symcon >= 5.0
Devices of the type Generic Slider can be set to are percentual value. Within Amazon Alexa, the device is interpreted as a common switch and can be used for different devices.
Parameter
Name Description
Name Name that is used to address the device via Amazon Alexa
Variable A triggerable variable of type Integer or Float
Possible Actions
Switch On or Off Switch the variable towards 100% or 0% "Alexa, switch <Name> on."
Set Value Switch the variable towards the given value "Alexa, switch <Name> to 40%."
Variable Possible Profiles
Variable ~Intensity.100, ~Intensity.255, ~Intensity.1
