Active List
Require: IP-Symcon >= 5.0
The 'Active List' shows all active variables in the Visualization and offers the possibility to switch them off simultaneously.
To do this, they must have been added to the list on the configuration page beforehand.
function scope
- Displays all active variables in the Visualization and allows switching them off.
Software Installation
- Use the Module Store to install the Active List module.
- Under "Add Instance" the 'Active List' module can be found using the quick filter.
- More information in the Instances documentation.
configuration page
Name | Description |
Turn Off Action | Creates an action to turn off the variable simultaneously |
Variables | A list of variables whose status is checked. |
Variables are considered active when ...
- the value of an integer or float variable is greater than the minimum value. If the variable has a .reversed profile it is considered active if the value is less than the maximum value.
- the value of a boolean variable is true. If the variable has a .reversed profile, false is the active state.
- the value of a string variable is not empty.
Accordingly, variables are considered inactive if ...
- the value of an integer or float variable is the minimum value. If the variable has a .Reversed profile, it is considered inactive if the value is the maximum value.
- the value of a boolean is false. If the variable has a .reversed profile, true is the inactive state.
- the value of a string variable is empty.
statusvariables
Statusvariables
Name | Type | Description |
Disable | Script | Disables all variables that are still active. |
Visualization
All active variables will be displayed on the Visualization. With a click on "Switch off" all displayed variables are switched to inactive.
