OW_WriteBytesMasked
boolean OW_WriteBytesMasked (int $InstanceID, string $Data, int $Mask)
Data | Sequence of bytes to be sent |
Mask | Bitmask of the bit to be set |
Sets a sequence of bytes (Data) taking into account a bitmask Mask from all pins of the device with the ID InstanceID.
Only pins defined as the output are described!
OW_WriteBytesMasked(12345, Chr(255), Chr(1)); //Set only Bit 0
