Data management
Require: IP-Symcon >= 4.0
A module basically has four different forms of managing data. These are properties, attributes, buffers and status variables. These differ in terms of task, access options and persistence.
Properties
Attributes
Buffer
Status Variables
Properties
Properties are persistent data of a module which should/must be configured by the user. This data is only saved when "Apply" is clicked. Properties are, for example, required login data, device ID or interval for calling up sensor values. This is usually done via the configuration page, which is defined via the form.json.
Function name | Brief description |
ReadPropertyBoolean | Returns the value of a boolean property |
ReadPropertyFloat | Returns the value of a float property |
ReadPropertyInteger | Returns the value of an integer property |
ReadPropertyString | Returns the value of a string property |
RegisterPropertyBoolean | Creates a boolean property |
RegisterPropertyFloat | Creates a float property |
RegisterPropertyInteger | Creates an integer property |
RegisterPropertyString | Creates a string property |
public function Create() { //Never delete this line! parent::Create(); $this->RegisterPropertyBoolean("EmulateStatus", true); $this->RegisterPropertyFloat("Faktor", 0.5); $this->RegisterPropertyInteger("DeviceID", 0); $this->RegisterPropertyString("Text", ""); }
Attributes
Attributes are persistent data of a module, which are only set by the module itself and saved immediately. These are, for example, tokens for encrypted connections or saved values of a scene control.
ReadAttributeBoolean | Returns the value of a boolean attribute |
ReadAttributeFloat | Returns the value of a float attribute |
ReadAttributeInteger | Returns the value of an integer attribute |
ReadAttributeString | Returns the value of a string attribute |
RegisterAttributeBoolean | Creates a boolean attribute |
RegisterAttributeFloat | Creates a float attribute |
RegisterAttributeInteger | Creates an integer attribute |
RegisterAttributeString | Creates a string attribute |
WriteAttributeBoolean | Writes in a boolean attribute |
WriteAttributeFloat | Writes to a float attribute |
WriteAttributeInteger | Writes in an integer attribute |
WriteAttributeString | Writes to a string attribute |
public function Create() { //Never delete this line! parent::Create(); $this->RegisterAttributeBoolean("BoolAttr", true); $this->RegisterAttributeInteger("IntAttr", 5); $this->RegisterAttributeFloat("FloatAttr", 3.7); $this->RegisterAttributeString("StrAttr", "lalala"); } public function BumpAndShow() { var_dump($this->ReadAttributeBoolean("BoolAttr")); var_dump($this->ReadAttributeInteger("IntAttr")); var_dump($this->ReadAttributeFloat("FloatAttr")); var_dump($this->ReadAttributeString("StrAttr")); $this->WriteAttributeBoolean("BoolAttr", !$this->ReadAttributeBoolean("BoolAttr")); $this->WriteAttributeInteger("IntAttr", $this->ReadAttributeInteger("IntAttr")*2); $this->WriteAttributeFloat("FloatAttr", $this->ReadAttributeFloat("FloatAttr")+0.1); $this->WriteAttributeString("StrAttr", $this->ReadAttributeString("StrAttr") . "öäü"); }
Buffer
Buffers are non-persistent data of a module, which should only be managed by the module itself. These are, for example, incoming data records that are not transmitted in one, but arrive gradually and therefore have to be put together. These are only taken from the buffer and processed by the module when the data record is complete.
GetBuffer | Returns the content of a buffer |
GetBufferList | Returns an array of all buffers |
SetBuffer | Creates a buffer |
public function ReceiveData($JSONString) { //Decode JSONString $data = json_decode($JSONString); //Parse and write values to our buffer $this->SetBuffer("Test", utf8_decode($data->Buffer)); //Print buffer IPS_LogMessage("IOTest", $this->GetBuffer("Test")); }
Status Variables
Status variables are persistent data of a module, which can be changed by the module at any time. These are visible in the object tree and are available for further processing and display in the Visualizations. Status variables are, for example, sensor values, actuator values to be displayed on the WebFront and status values for further processing.
DisableAction | Disables the default action |
EnableAction | Activates the default action |
GetValue | Returns the value of a variable |
SetValue | Sets the value of a variable |
MaintainAction | Calls DisableAction or EnableAction |
MaintainVariable | Configures a status variable |
RegisterVariableBoolean | Creates a Boolean status variable |
RegisterVariableFloat | Creates a float status variable |
RegisterVariableInteger | Creates an integer status variable |
RegisterVariableString | Creates a string status variable |
RequestAction | Sets the value of a status variable |
UnregisterVariable | Deletes a status variable |
public function Create() { //Never delete this line! parent::Create(); // Variables $this->RegisterVariableString("TextData", "TextData", ""); IPS_SetHidden($this->GetIDForIdent("TextData"), true); $this->RegisterVariableString("SimulationView", "SimulationView", "~HTMLBox"); $this->RegisterVariableInteger("SimulationCounter", "SimulationCounter" , ""); $this->RegisterVariableFloat("Factor", "Zoom Factor Wall Display", "Factor.Display"); $this->RegisterVariableBoolean("Active", "Simulation active", "~Switch"); $this->EnableAction("Active"); }
