IPS_SetStatusVariableUseAction
bool IPS_SetStatusVariableUseAction (int $InstanceID, string $VariableIdent, bool $UseAction)
| InstanceID | ID of the instance |
| VariableIdent | Status variable identifier. A listing can be found on IPS_GetStatusVariableIdents |
| UseAction | Indicates whether the action should be used in the visualization |
The documentation of this function only for compatibility reasons and should not be used in IPSymcon 2.5 and newer versions. Since version 2.5, the functionality is only emulated and should be replaced by other functions. Since version 4.0, these functions can only be accessed if the Special Switch "Compatibility Functions" is activated.
The command sets whether the internally linked action of a specific instance InstanceID and the status variable with the status variable identifier VariableIdent should be used.
IPS_SetStatusVariableUseAction(12345, "StatusVariable", false); // Do not make it switchable via WebFront
// Replacement function since version 2.6
$VariableIdent = "Statusvariable";
$InstanceID = 12345;
$UseAction = false;
$id = IPS_GetObjectIDByIdent($VariableIdent, $InstanceID);
if ($UseAction) {
IPS_SetVariableCustomAction($id, VARIABLE_ACTION_NONE); // Enable default action
} else {
IPS_SetVariableCustomAction($id, VARIABLE_ACTION_DISABLED); // Disable default action
