IPS_SetLinkChildID
Require: IP-Symcon >= 2.1
boolean IPS_SetLinkChildID (int $LinkID, int $LinkedObject)
LinkID | ID of the link |
LinkedObject | ID of the target object for the link |
The documentation of this function only for compatibility reasons and should not be used in IPSymcon 2.6 and newer versions. Since version 4.0, this command can only be accessed if the Special Switch "Compatibility Functions" is activated.
The command binds a specific object with the ID LinkedObject to the link with the ID LinkID and thus the link refers to the object.
IPS_SetLinkChildID($LinkID, 12345); //Refer to object 12345
