IPS_IsPersistent
boolean IPS_IsPersistent (int $ObjectID)
| ObjectID | The ID of the object |
TRUE, if the object is saved, FALSE otherwise
This function should not be used any more since version 2.6. As all objects within IP Symcon are persistent, this function is not needed any more.
This function checks if the object with the ID ObjectID is saved in the Settings. This is currently done for all IDs that are bigger than 10000. Otherwise, the object is discarded when IP Symcon shuts down.
if (IPS_IsPersistent(34881))
echo "The object is saved on shut down!";
