IPS_HasInstanceParent
boolean IPS_HasInstanceParent (int $InstanceID)
InstanceID | ID of the instance |
The return value is TRUE if the instance has a parent instance, otherwise, FALSE.
This function should not be used since IP-Symcon 2.6 and was removed with IP-Symcon 4.0.
The command indicates whether a particular instance InstanceID, seen by the hardware (physical) view, has a parent instance e.g. a splitter or I/ O module.
This command is only useful for devices and splitter instances.
// Up to Version 2.5
if(IPS_HasInstanceParent(12345))
echo "Has a parent instance";
// Since Version 2.6
if(IPS_GetInstance(12345)['ConnectionID'] > 0)
