IPS_GetScriptID
int IPS_GetScriptID (string $ScriptName)
ScriptName | ScriptName to search for |
Since IP-Symcon 2.5 this function can no longer be used. Old IP-Symcon 1.0 functions have been removed with this release.
The function tries to get the ID of the script named ScriptName. The ID of the first script found with a name that matches ScriptName is used. If such a script was found, its ID is returned, otherwise 0 (zero).
The IPS_GetScriptIDByName function offers a more secure method of determining the ID.
Caution: Since names can be assigned arbitrarily in IP-Symcon and are therefore not unique, the function can report an incorrect ID.
//Suppress error message with @
$ScriptID = @IPS_GetScriptID("Rain Capture");
if ($ScriptID === false)
echo "Script not found!";
else
echo "The script ID is: ". $ScriptID;
