IPS_GetInstanceParentID
 int IPS_GetInstanceParentID (int $InstanceID)
| InstanceID | ID of the instance  |
ID of the parent instance
This function should not be used since IP-Symcon 2.6 and was removed with IP-Symcon 4.0.
The command returns the ID of the parent instance for the instance InstanceID. (Seen by the hardware (physical) view)
This command is only useful for devices and splitter instances.
F
// Up to Version 2.5
echo IPS_GetInstanceParentID(12345);
// Since Version 2.6
echo IPS_GetInstance(12345)['ConnectionID'];
