Compatibilityfunctions
Compatibilityfunctions are the deprecated features that should no longer be used and are disabled by default. These were abolished due to performance or replaced by improved replacement functions. For reasons of compatibility with old IP-Symcon installations, these can be activated via the special switch "compatibility functions" if required. However, this requires a lot of resources and is strongly discouraged.
