Single Element
Require: IP-Symcon >= 7.0
Enables the display of an element from a List as a single tile.
Requirements
Each Instance can be displayed as a Single Element. The presentation is automatically selected if an instance only has one sub-object. Alternatively, it can be selected for each instance with multiple objects via "Edit Tiles".
As own Tile
If the Tile is opened, all objects of the instance are displayed as List.
Appearance in the WebFront
This display is not supported by the WebFront. Instead, the instance is displayed as List.
