IPS_LogMessage
boolean IPS_LogMessage (string $Sender, string $Message)
Sender | The sender |
Message | The message |
The function writes the message Message into the log file and provides the sender Sender. The string Sender should indicate the cause of the report, e.g., the name of the script. The message is immediately available in the message view as "Custom Message".
$ScriptStart = microtime(true);
// calculate a lot...
$ScriptTerm = microtime(true) - $ScriptStart;
IPS_LogMessage($_IPS['SELF'], "Term is ". $SkriptTerm. "sec");
