IPS_GetLogDir
Require: IP-Symcon >= 4.0
string IPS_GetLogDir ()
The full path to the IP Symcon log folder
The function returns a string containing the full path to the IP Symcon log folder. Depending on the operating system, the path contains a trailing slash ("/") or backslash ("\").
echo IPS_GetLogDir();
// Examplary output:
//Windows
"C:\Programs\IP-Symcon\logs\"
// Linux, RaspberryPi
"/var/log/symcon/"
// MacOS
"/Library/Logs/Symcon"
