IPS_GetKernelDirEx
Require: IP-Symcon >= 4.0
 string IPS_GetKernelDirEx ()
The full path to the IP Symcon installation folder
The function returns a string containing the full path to the IP Symcon installation folder. Depending on the operating system, the path contains a trailing slash ("/") or backslash ("\").
echo IPS_GetKernelDirEx();
// Examplary output:
// Windows
C:\Programs\IP-Symcon\
// Linux, RaspberryPi
/usr/share/symcon/
// MacOS
/Applications/Symcon.app/Contents/Service/
