Program Information
IPS_FunctionExistschecks if a specific function exists
IPS_GetAvailableUpdatesreturns an available update for the configured update channel
IPS_GetFunctionreturns extensive information about a function
IPS_GetFunctionListreturns a list of all available functions
IPS_GetFunctionListByModuleIDreturns a list of all available functions of a module
IPS_GetKernelArchitecturereturns the architecture that IP-Symcon was created for
IPS_GetKernelDatereturns the kernel creation date
IPS_GetKernelDirreturns the path to the IP Symcon program folder
IPS_GetKernelDirExreturns the path to the IP Symcon installation folder
IPS_GetKernelDirSpacereturns the total/free/available disk space of the drive on which all data of IP-Symcon is stored
IPS_GetKernelPlatformreturns the operating system which IP-Symcon is running on
IPS_GetKernelRevisionreturns a unique revision identifier
IPS_GetKernelRunlevelreturns the run level of the kernel
IPS_GetKernelStartTimereturns the point in time when IP-Symcon was started
IPS_GetKernelVersionreturns the version number of the used kernel
IPS_GetLiveUpdateVersionreturns a version identifier made of the build date and revision of the kernel
IPS_GetLogDirreturns the path to the IP Symcon log folder
IPS_GetSystemLanguagereturns the system language of the operating system on which IP-Symcon is running
IPS_GetUpdateChannelreturns the currently configured update channel
IPS_LogMessageWrites a user defined message into the log file
