IPS_RunScriptText
 boolean IPS_RunScriptText (string $ScriptText)
| ScriptText | String which is called as script. |
The command starts a script with the content ScriptText. It is not necessary to state PHP tags.
When using IPS_RunScriptText, the script is executed in its own context. Thus, it does not have access to the variables of the calling script. Data can only be exchanged via external variables. The command is suited for situations, where a script needs to be executed soon but does not require the context of the calling script. The runtime of the scripts do not change as both scripts are executed simultaneously.
// Prints "Hello World" in the message view
IPS_RunScriptText("echo 'Hello World';");
