IPS_RunAction
 bool IPS_RunAction (string $ActionID, array $ActionParameters)
ActionID
GUID of the executed action
ActionParameters
List of Parameters for the executed action
This function causes the execution of the Action with the GUID ActionID and the parameters ActionParameters. The execution runs concurrently (at the same time) to the calling script.
The action parameters need to include the following entries:
Parameter Description
TARGET ID of the target object of the action (-1 for general actions)
ENVIRONMENT The execution environment of the action, see Environments
PARENT ID of the object that executes the action, e.g. the PHP script or the Flow Script
// Execute Script with the ID 12345
IPS_RunAction("{7938A5A2-0981-5FE0-BE6C-8AA610D654EB}", ["TARGET" => 12345, "ENVIRONMENT" => "Default", "PARENT" => $_IPS['SELF']]);
// Show all actions and their GUIDs
foreach(json_decode(IPS_GetActions(), true) as $action) {
    echo $action['id'] . " -> " . $action['caption'] . PHP_EOL;
    // var_dump($action); <-- Shows more details, for example: restrictions
