Process Control
IPS_Execute | Starts an external program |
IPS_ExecuteEx | Starts an external program in the user context |
IPS_RunAction | executes a single action |
IPS_RunActionWait | executes a single action and waits for the result |
IPS_RunScript | starts another IP-Symcon script |
IPS_RunScriptEx | starts another IP-Symcon script and passes variables |
IPS_RunScriptText | starts text as IP-Symcon script |
IPS_RunScriptTextEx | starts a text as IP-Symcon script and passes variablesstartet einen Text als IP-Symcon Skript und übergibt Variablen |
IPS_RunScriptTextWait | starts a text as IP-Symcon script and waits for its execution |
IPS_RunScriptTextWaitEx | starts a text as IP-Symcon script, passes variables, and waits for the execution of the script |
IPS_RunScriptWait | starts another IP-Symcon script and waits for the result |
IPS_RunScriptWaitEx | starts another IP-Symcon script, passes variables, and waits for the result |
IPS_SemaphoreEnter | allows the synchronization with other simultaneously run scripts |
IPS_SemaphoreLeave | allows the synchronization with other simultaneously run scripts |
IPS_Sleep | delays a script for a specified duration |
